Streetglow lighting questions | Ford Explorer Forums
bigwayne3000
Frenchtown, NJ
99 Sport
I'm looking to put in some neons in my 99 Sport. Mostly looking for the front probably under the dash so it shines down where your feet are. When looking at streetglows site they also sell this neon rope that you can use to outline the dash or arm rest or doorpanels etc.. Anyone use this stuff? How does the rope work? Am I able to cut it off in sections or do I have to somehow just make it to one continuous loop til I run out? Its only sold in 5 and 10ft sections so I'm not sure how this stuff will work if I want to just use it on my arm rest and up around my radio etc section which obvi isnt 10ft. I'm purchasing streetglows neon pedals which are clearanced now for 9.99. Ill let you all know how that goes. At some point I want to put in the sound activated module so the neons go with my music. Any help you all can provide is greatly appreciated. Thanks guys!!
I have the music device you are considering. It is pretty neat but I did have some trouble with it. Ill try to get some video on here soon. Until then, you can check out the pics on my cardomain at the bottom of this page.
Forget StreetGlow...look into products from www.Oznium.com If you're looking to add some glow to your interior, get some cold cathodes. Thinner, lighter, stronger, and brighter...not to meantion cheaper than neon tubes. I used to run two pairs of green 12" cathodes that shined down on my footwells.
Oznium.com also has a great selection of underbody kits, some of them absolutely ridiculous. I'd take a look at their LED ones. Brighter, more patterns, and more durable than conventional neon.
Good luck!:thumbsup:
