EasyRhino
- March 25, 2001
- Kailua, Hawai'i
- '02 Limited 4.6L 4x4
Vehicle: 97 XLT 4 dr 5.0L AWD, no lift, no offroading.
OEM tire/wheels: P235/75R15 on factory alum. wheels.
Factory Goodyear WIlderness A/Ts went 55K before GY replaced due to cord separation. Prorated at 50% worn.
Replacement Goodyears now at 26K and are out of round, driving me nuts. Probably 25% worn.
What about this:
Replace with LT tires in the largest diameter size allowed for the factory wheels/ride height/street use that don't produce excessive road noise.
If my math is right, P235/75R15s are 29" tall and 9.4" wide. Also, they do not fill up the tire wells.
Also, if may math is right, if I can use a 31" tire, it will effectively reduce the axle ratios, improving gas mileage and reducing drivetrain wear.
(29/31)(3.73) = 3.49, or a factor of approx. 6.5%
The question is: What is the biggest tire I can use, and how do you correct the speedo for the error?
I know this is review to you guys that have experience with this stuff, thanks for bearing with me.
What about this:
