AP9
- July 23, 2012
- Chicago SW suburbs
- 2000 XLT 4WD, 4.0L OHV V6
I don't really have time or space to tear the upper engine apart again just to experiment around, so hopefully you folks who are smarter than me can advise.
Back in March I ran some Seafoam through the intake manifold. Then one day in April while driving on the highway I felt it start to misfire, but thought/hoped I might have been imagining it or just driving on rough road. The day after I was on a longer drive on a stretch of highway (about an hour and a half each way), and halfway to my destination I started feeling it again. Several minutes later I sure enough got the flashing CEL and pulled a P0301, and watched my fuel economy tank (something like 14 mpg at steady 70 mph). Had to fill up -- no change after a new tank of mid-grade, it just misfired all the way home. Removed spark plug #1 and found it completely saturated in oily sludge and a little bit of hard deposits -- cleaned it and reinstalled. Since then, I've had similar situation happen twice, about 800-1000 miles apart. Also threw the occasional P0401 a couple times.
The engine, which never burned any oil in the first 212,000 miles of its life, is now consuming oil at about 1 quart every 200 miles. The exhaust is now slightly smoky (not blatantly so) and always smells like raw exhaust, whereas it only used to smell upon startup during very cold weather. As far as I can tell, there are no visible leaks except for minor front & rear main seals (which haven't gotten noticeably worse over the past 5 years). PCV valve and air filter are good; no evidence of any vacuum leaks. Fuel economy is good except when misfiring. No unusual engine noises except the "usual" valve lifter noise.
I'm suspecting the Seafoam either blew out a valve seal on cylinder #1 (is that even possible?) or caused a stuck ring. Does it sound like the catalytic converters are shot (though I'm not throwing a P0420 or other codes), or will I have to fix the other problem first to know for sure?
