JRLCrist
- February 25, 2007
- Stewartstown, PA
- '93 X EB & '00 Olds Alero
Okay, here's the scoop. I have two issues that just came up after driving from coast to coast (moved from PA to AZ). First, here's what's happening. My truck will start and the temp gauge will read cold. After about 30 seconds of being on the road, it'll race all the way up to near redline in about 5 seconds flat. The second problem is my oil pressure gauge. I have a feeling a sensor is buggy because it'll read normally, but after a few minutes if I stop at a light or start to go into the lower RPMs, it reads 0 pressure. Here's what I know from poking around. I popped the hood and saw that the fans were running, which to my knowledge is good. Before the cross-country trip, I replaced the spark plugs and noticed that one of them looks very... well, sandy brown, while the rest still look shiny. I haven't done anything with it yet because I don't have my rachet set here yet and I wanted your opinions. I also noticed that about two mornings ago I had white smoke coming out of my exhaust pipe and that ever since I started up into the mountains, I've had next to no power and have been having a hell of a time even hitting 15mph (after that I'm okay). I know I have multiple holes in my exhaust pipe that weren't there before, but then again the pipes were a tad rusted anyway and I hope to replace them with some stainless steel ones. The only other two details I can think of are when the temperature jolts up like that, I blow my heat on high and it's hardly even hot at all. Also, I checked my oil levels, and they're fine. Granted I need to get my oil changed like tomorrow, would that make a difference?
Any help would be appreciated
EDIT: I jsut took off the radiator cap and saw that my overflow was full because I jsut refilled it a few days ago, but my radiator was bone dry. I started to put more in, but how did that happen? I didn't see any leaks when I just poured some in.
