Superlift SOA perches | Ford Explorer Forums - Serious Explorations
jrgaylor
Washington
1985 BroncoII
Does anyone have the part# for the superlift SOA perches that have the shock mounts on them?
Joe
type "superlift soa perch number" and got SUP1160. took em like 15 seconds. lol there yea go. are you going to be soaing soon?
BY spring I will have more lift and should be locked.
Joe
Don't forget.....PICS!!!
If you are going SOA, I would stay away from the Superlift brackets. I've broken several.
NOTAJP: What should he do then if you say you've had problems? What else is out there? What kind of problems have you had?
Weld on spring perches and shock mounts. It's pretty cheap. I've had issues with cracking the Superlift brackets.
i have seen people just use the stock plates and flip them over... then they used the lower bolt hole where the swaybar used to attach for the shock....
