DaaQ
- August 9, 2015
- South KY
- 2003 Explorer XLT 4x4
Hi all, I will be replacing hubs all the way around strut assemblies BTF spacer and UCAs brakes rotors and anything else I find.
This is an 03 ex. Main question I'd like advice on would be the lower ball joints. Should I go ahead and replace them and one of the lateral links that connect to the rear end with the bad wheel bearings feels looser that the drivers side. Since they aren't terribly expensive should I go ahead and replace those as well?
And since I'll have the knuckles/spindles all off how about bushings and axle diff seals and should probly do pinion seal on rear differential as well, which leads to u joints.
Budget is a concern because I don't want to loose my tire budget.
Thanks for any input. And difficulty of the ujoints and seals are my main concerns.
Jim.
Jim.
