$300ExSport
- December 2, 2010
- Orlando, FL
- 1996 V8 Explorer
Hey everyone, this is my first post here but I've used the forums in the past for info.
I got a 1998 Explorer Sport with 110k miles and a bad transmission(fluid had spewed out of the relief valve and previous continued to drive until empty and burned up the clutches). I bought it for $300 and decided the bands were worn because I could get it to move forward and reverse about 5mph at wide open throttle.
I went to my local junkyard and pulled a transmission out of a 2006 Ford Ranger which hit a tree(bark was wedged in the bumper). Paid $100+tax
I tried but couldn't rotate the engine to get the 2006 Ranger torque converter out because the whole front of the truck was smashed into the front of the 2.3L 4cyl and would not move. It's sad because the TQ would have been included free with transmission purchase...
Long story short, after flushing the lines out with air and installing the transmission using the original 1998 torque converter, the only movement I get is in "1" on the column shifter. No reverse, does not engage when in "D" or "2", just "1". There was one extra sensor on this new transmission that I did not have a plug for because it is an ISS Sensor which is supposedly only use to provide smoother operation of the transmission.
1. My fluid levels are fine, filled with Merc V as per specs.
2. It's definitely a 5r55e and went in without a hitch(after swapping bell housing)
3. I can peel out in first so it's definitely engaging but not shifting any higher than first.
If it helps anyone, I am attaching pictures of the vin stickers from both the doner vehicle and the destination vehicle.
Can somebody help me figure out why I only have drive in "1"?
