bigrob123
- November 29, 2011
- Cape Cod, MA
- 99 explorer xlt
i was wondering what it would take to switch my corner light and use a low powered bulb that is bright enough to see in the dark but be dim so i can go places im not supposed to be drawing as little attention as i can. i want it completely isolated to its own switch and to run off my second battery. i kinda dont want to run all new wires so i was hoping to cut the wire at the light switch where i think it is and solder a attachment wire to make it to my switch board is. so if some one could tell me where the wire is located nearest the cab to attach to the corner lights. what size wire should i use? and should i run a relay? so every one knows it a 99 ford explorer xlt.
