T-case swap | Ford Explorer Forums
T-case swap
4X4_'97_Sport
Corning, NY
'97 Sport Control Trac
I own a 97 Explorer Sport Control Trac 4x4 that I want to put a manual shift tranfer case out of a 88 Bronco II (my current project) in it. Would the transfer case out of the Bronco II bolt into my Explorer?
if its a manual borg warner 1354 then it should bolt right up. mine did... don't know what others would work.
the BII is a 1350, slightly different then the 1354, the difference is the yoke for the front driveshaft.
You will need new/modified driveshafts most likely...
Thanks for the info. Now for my next question I would like to get the Pre-Runner look on my 2dr explorer, I can find the front fender but I can't find anything for the rear. Does anyone know where I could find some rear Pre-Runner quater panels for my 2dr explorer?
