t case swap | Ford Explorer Forums
t case swap
jd3z400
hopewell jct ny
01 sport
hi i need a little help i have a 01 sport and my t case is bad so i want to go with a manual one so what do i need and which one fits the 5r55e and is there a tread on doing the swap??? thanks justin
thanks for the info but y do i need a shaft from a 97??
The output on the 98 and newer transfercases, for the front differential, is a 6 bolt 'cup'that has a CV joint that bolts in to it. 96 and 97 trucks used the double cardan style shaft, wich has a u-joint at the transfercase end. That's what you need to bolt it up.
