Tailgate Repair | Ford Explorer Forums
Tailgate Repair
BTRs X
Maysville, KY
'92 Explorer XL 4x4
I purchased a 1992 Ford Ranger and the tailgate won't open when you pull the handle. How do you fix this? Right now I have to use a screwdriver to open it. Thanks.
when you open it do you have to lift tabs on the sides of the tail gate? my dodge had locks on it it was quite strange.... i think ther perosn before me had a cap on it....well then made it a flat bed.
I have to push in the little tabs on either side of the tailgate to open it..the ones that hold it shut.
i believe it is a cheap plastic clip piece...you get to it from the bed side of your tailgate...a panel on the tailgate...open it and you will see the faulty piece..it is a plastic piece that goes from the handle and attaches to a rod for the tailgate latch...
How do you replace it and where can I get it from? Thanks for the help.
first, verify that is the problem...if it is not it might be and it is rare, the handle itself...the plastic piece and a replacement handle can be picked up at pep boys and i think autozone...the handle is like 20 bucks and the pair of plastic clips i think is a buck...or you could go to a junkyard for the handle...but if it is the plastic, replace all of them, if you have only 2 or if you have 4 pieces...it's cheap and easy...
Thanks. I just got the truck yesterday and Im going through it right now fixing all the little stuff. Today I fixed the fuel gauge. Tomorrow Im going to fix the tailgate and wax it. Thursday figure out why the 4x4 won't come on. Next week it gets new shocks, replace 1 cab mount, and new tail pipe. Then hopefully Im done for awhile!
