TCC Solenoid Part P0741 Stuck OFF | Ford Explorer Forums
swhird
2002 Ford Explorer
On my 2002 Ford Explorer XLT V6, I get P0741 Torque Converter Clutch System stuck OFF. I thought I should replace the TCC solenoid but every auto parts place I check does not have a part that fits this model. I'm not sure what's going on with that. Does anyone know what the part number is? Can I buy just the TCC solenoid?
Thanks.
I believe the solenoids in your trans are all included in a solenoid block
So you have to replace them all together
I would clear the code see if it comes back
Then inspect the external wiring to the trans
Then I would check continuity between the pcm and solenoid wires
Then you can do an ohm test from outside the trans to confirm the tcc is bad
Finally I would drop the pan and have a look see, replace the pack
Thank you. That appears to be the case.
