Code Reader
Dead Link Removed
You should be able to get one of these at your local parts store, like Autozone or Checker to read the ABS brake codes. But...
If your red brake warning light is on as well as the abs warning light then you've got or you had air in the system.
The red brake light indicates a pressure split between the front and rear brake circuits. You can turn this light on when you are bleeding the vehicle if you don't do the longest path first.
Do the RR wheel, then the LR wheel, then RF finally the LF. For reference, the RR wheel is on the passenger side.
Then...
To turn the light off:
The pressure warning switch is like a center off toggle switch and it resides in the 'proportioning' valve. To turn it off you have to create the opposite conditions that led up to the switch setting.
If you had a leak (bleeding) in the rear of the vehicle that set the light then you have to bleed the front to center the switch again.
Be aware that you can push the switch all the way from the existing setting to the opposite fairly easily and it you might get confused. Push the brake pedal gently while watching the light....
Bleed one of the front or rear wheels while watching the light. After a certain amount of fluid escapes from the front or rear the warning light switch should get pushed back to the off position.
Disclaimer: Brake systems are the most important safety item in your vehicle - if you don't feel comfortable doing the work safely then contract it out. Don't take your life in to your hands!
Jon
