Tell me how to wet sand | Ford Explorer Forums
RTStork
Grand Bay, AL
99 Explorer XLT 5.0L 2WD
What grit sand papers and how to do it would be great. I'll be practicing on some scrap metal, but I intend to paint and sand some plastic pieces too. Is the technique the same for plastic?
Keep the paper and surface wet... and keep the pressure light, till you see how the sanding affects the plastic or metal. :)
hope that helped a bit!
Pete
Ok, got that. Now, what grit sand paper do I use? Or do I need several diff grades? I pretty much need a detailed description from start to finish since I know nothing about how to do this. Thanks.
It depends upon what you are trying to accomplish by wet sanding. If you are smoothing out bodywork (after using a grater) to prep for painting or stripping paint, start with 320 grit. If you are sanding primer or paint to put a new coat on, I usually use either 500 or 600 grit. If you are sanding a finish coat to remove orange peel, you can start at 600 (be VERY careful with the pressure) and then go up to 1000 or 1200 for final sand before polishing compound. One thing I would recommend is to use a sanding block of some kind. Flat for the large flat areas, or a flexible one for the curves. If you use just your hand, you won't get as smooth a finish since your fingers will apply uneven pressure to the sanding surface. This is especially true for plastic pieces.
If you are sanding around edges, you are better off sanding up to the edge from both sides, than over the top of the edge. When you sand over an edge, you almost always will strip the paint completely off the edge before you get the adjoining surfaces where you want them to be.
Another thing I do is use a running water supply instead of a bucket. With a bucket, you are bringing contaminants back to the sanding surface when you dunk your sanding block. With a hose, you are constantly removing the sanding contaminants.
Also, soak your paper in water for an hour or so before sanding. This helps soften the paper up so it conforms better to the body panels (If you are doing curved surfaces), and keeps it from creasing.
soak the sand paper in soapy water....
This is a dead thread...but FINALLY i know how to wetsand :D
Just a note since Brian defibullated this thread- I just wetsanded the clearcoat on the SHO last night. I used 2000 grit and a hose- came out amazing. Pics coming soon... :)
Yea man lets get some pics lol
I might have to try that on my 95...
How long did that take you? The whole car??
Joe,
What kind of SHO, do you have, I have a 95 ATX.
'99 SHO. It's the 9th SHO I've owned, I've owned every year except for a '98.
I only wetsanded the rear 1/4 after needing to repaint it after a run-in with a wrong-way driver on an icy road a few months back...
CLICK ME
Ahh yes, I remember that thread a while back, I LOVE the taurus SHO's, but I dont really care for the regular tauruses lol
I'm getting the windows on the new doors re-tinted this week, and I'll put up a start to finish album. Not much along the lines of how to, since it isn't very difficult, but I'll put in what I did. It came out amazing...
nice man
cant wait to see pics :D
is napa the best place to buy match up paint from to spray???
meijers has a good big selection...
