So wondering, what are the weak spots of these cases, where are they breaking. How are they breaking.
The how and where( on the case) will tell you plenty of how to mount the t-case
Pictures help. Stories help.
The strongest t-case mounting system won't help if your motor mounts and trans mount ( if there) are not in good shape.
Just wanna make sure young Jon here doesn't bust up a case.
I have no other experience then my Atlas 2.
I contacted the builders/designers Advanced Adapters concerning the problem of the amount of torque twisting.
I mentioned that on the pirate 4x4 there was this guy (Vista) who is well regarded in everything 4x4 and he built a doubler and was making a torque controlling device that connected to his doubler. Advance told me,
What ever I do,do not connect anything to the case. The guys doubler grenaded on him. Do not know the exact cause? Now I will say this, an Atlas is an all aluminum billet case, where his was steel.
What I've read, which is not first hand knowledge, one weak point is the two piece sector shaft that needs to be made by joining two shafts together.
This part is all about Metallurgy at it's best. Enough said. Other then I chained the engine to both sides of my frame.
And a good thing to, just a few days ago I had to pull a chevy 3/4 ton truck up a dirt hill after he broke a dana 44 outer axle. With my axles all locked and Atlas in low, should have seen all the dirt flying from all 4 wheels. But had I not have had some restraints built in, who knows what would have happened cause that engine never even hinted of a strain. I just wished I had a video of it doing the "Boot Scootin Boogie".
Still thinking of adding some cushioning devices utilizing those hard poly after market bushings that could be place up against both side of engine or bellhousing or tranny.
The poly bushing would be hard connected to some steel support and then lay next to the drivetrain not hard bolted Bet it would work like a champ.
But don't worry, I have all confidence that young Mr Jon will utterly destroy the case. Reason, not the case itself, but his throwing caution to the wind, Hell bent for Leather, unadulterated driving style.
But all sector shafts don't let go but some do. Just depends on a lot of variables.
For example, you guys with less then a 4" bore motor with a power stroke of every 120 degrees of crankshaft rotation probably won't have much to worry about veses a 4" bore that fires every 90 deg. of cranshaft rotation...just saying
