Hi,
I had a problem with my 1997 Ford Expy Control Trac 4WD. While deeply turning either left or right at low speed, there were a repeated noise coming apparently from the front and a vibration that almost shakes the vehicle and you can feel it in the weel.
I've read maybe in this or other forums that it could be a bearing or something else in the suspenssion, or a failure in one or both differentials, or different diameter tires installed in the front end. I also read in other thread that this behavior could be related to a bad sensor and when turning to left or right the GEM reads a slippage in wheels and engages the 4WD.
So I basically did the brown wire mod as a start point to figure out what is happening with my truck:
1.I did a drive test, did some deep turns and the vibration and noise were there.
2.I cut the brown wire under the driver's seat.
3.I did a second drive test. The vibration and noise were gone. I'm happy.
Now, I have some questions to all of you, more experienced Explorer owners:
While it can be a workaround, I don't want to have this brown cable mod installed. I want to fix the problem and let the truck work as it was intended to. So I can't figure out what the signals are telling me. What component is not working properly? Torque On Demand relay, Transfer Case Clutch Coil, GEM, other?
Please advice.
Sorry for my english.
