The Ex is in a bad way!! | Ford Explorer Forums
BIGHVM
UK, Richmond, Surrrey.
2000 Northface
Guys I have not posted for ages- hope your all well and cars are good!
Mine is still up in the air, had some nightmares with balljoints- I knew the bottom ones were bad but when I went to change them, the top ones were found to be so knackered that you could blow on them and they would move!!
the rubber was shot and there was no tension at all, so I thought well lets go for it and got the modified parts, ( all one piece) and have started it!
So far drivers side is done including new shocks and a hub and track rod ends, I have to do the other side same again and may as well service her oils etc whilst I am at it!!
weather is a bit iffy and also the short day light but hey ho- thats what owning an Ex is about!
Good to be back guys, let me know your all well and doing ok!
Good to see you back and able to sling the spanners H
Jan
Hi H, I'm doing the very same thing right now. New upper arms, and I've put new bushings and ball joints in the bottom arms. I've got to change the steering rack again, and its being a right bar steward!!!! Hope you are well.
