cmayna
- January 10, 2002
- Menlo Park, Ca
- 96 EB & 97 Sport
Prior to this weekend, I was leaking coolant as if I was a water truck. In addition when this problem reared it's ugly head, I noticed that my gauge starting jumping quickly from cold to hot and back. Replaced both upper and lower intake
manifold gaskets along with thermostat and sending unit.
Yes, the lower man gasket was the culprit. No more leaks !
Anyway, before the recent leak and erratic gauge showed up, my temp was very consistant with the needle staying around the O&R in "normal". Now with the new thermostat, it sits between the R&M going down the highway but as I start up a climb it raises between the M&A.
I saw in other messages that you need to make sure
that when installing the thermostat, the little
weeping hole on the stat needs to be in a 12 o-clock position. Is this true ? Does it warrant me going back confirming it's location ? I got this stat from a local ford dealer.
Also What about burping the radiator ? I heard that it's possible I may have some air in my coolant lines which may cause the needle to jump around. How do you burp (belch) the air bubbles out of the coolant lines ?
