Russ in CT
- November 11, 2002
- Milford, CT
- '99 XLT
OK, I am apparently a moron, somebody keep me away from the toolbox.
Over the weekend I did TSB 03-22-10, to correct a sloppy 2-3 shift and no engine braking in 1st. After a slight mishap with not connecting the manual valve (thanks to Glacier99 for knowing just what was wrong), and getting to take another red shower, everything seemed OK, 1st was fixed, shifting seemed better, no leaks. I drove it around for about 15 minutes, and declared it done.
So the wife takes it out the next day, says its driving much better, but we got a code to pull (O/D light flashing). OK, I'll have to take it somewhere and get the code pulled. But the next day, yesterday, she needs to take it again. She left early, and when I went out I noticed some tranny fluid in the driveway. OK, guess I got a leak, gonna have to take care of that tonight. But when the wife gets home she calls and says its smoking and making bad noises. I figure the leak is dripping on the Cat, causing the smoking, but the noise thing has me worried, it didn't seem like that big a leak.
So I get home and the speedi-dri I put down in the AM now has a gorge in it where a flood (a red one) had apparently washed through, and man does it smell bad
I pull the dip stick, and its bone dry, and smells. I crawl underneath and can't really find much evidence of the leak. A little moist around the gasket, and also around the new drain plug I installed, but the pan itself is pretty much bone dry, as is the Cat. If it was the gasket, I would have expected to see large runs down the side of the pan, and all over the underneath as it got blown around at highway speed. I can only assume its that drain plug I installed. So I added a couple quarts of tranny fluid, and waited, and waited, not a drip.
How did this thing manage to leak so bad that I lost all the tranny fluid in one day, yet I can't get it to leak one drop after I add fluid? It didn't leak when I first put it together, it doesn't leak now, maybe only when it gets warm it starts leaking?
I didn't like the looks of that drain plug kit when I opened it, I should have tried to find a better one. Its from Pep-Boys, its got a pair of plastic washers that go on either side of the hole in the pan, seems OK, but the drain bolt just has this stupid o-ring on it. If you tighten it down too far, it just bulges out at a point, and you have to back it off enough to let it reseat and try again. No grove or anything for the o-ring, it just sits there like a washer. I used lock-tite on the threads that secure the kit, and torqued it down well, but that drain plug was as tight as I dared make it without getting a bulge.
It didn't leak when I put it together, so I figured if I had any problems down the road, I could come up with something better than that stupid o-ring.
So asumming it only leaks when it gets hot, and somehow leaks enough to lose most of the tranny fluid, and got hot enough to cook the tranny fluid that ended up in the driveway once it got home from its ~30 mile last ride, how much hope is there my tranny survived?
Should I just tow it to a tranny shop and tell them to rebuild it? (I'm guessing that is gonna be in the $2K range, wife will kill me if I don't do it myself first) Should I pour in some more fluid, start it up, and see what happens? How do I flush out all the burnt up fluid that is still in there (in the TC, etc)? Should I try to find a used tranny to drop in there?
How did this thing still move without any fluid?
