thinking about replacing running lights.. | Ford Explorer Forums
G
gensic11
quick question, i noticed on my 97 theres 3 different bulbs for the running lights on each side. my passengers side corner bulb is out, can i get that at auto zone? all of the bulbs and just replace them all? and how much would i be looking at? and how easy is it to replace?
Yes, All the bulbs can be purchased at AZ. They come in 2 packs for about 3 or 4 bucks each. I would only replace what is burned out. There is a flap under the hood that says "lift for headlights" or something close to that, there are 2 screws that hold the L-shaped corner housing in place. Unscrew the screws and give the corner a tug. Simple as that... good luck man!! MATT
Light bulbs are fairly cheap and since you already going to take the time to replace one of them you might as well do the rest of the bulbs in the same area. Most likely they are about to go anyways. Also, its not a question whether Autozone (or Pep Boys) got them or not, they got them. The question is which brand you should get. As long as you stay away from the cheaper brands you should be fine.
thanks for all the help, im gonna go replace them sometime today... i know it was probably a stupid question.. hey i can do a complete amp bypass in my car by myself but im not sure about the lights. lol.. thanks for the replies.
