Tw|tch
- May 25, 2010
- North Carolina
- '95 XLT
Before i begin, I am pretty certain this should be posted somewhere else, please move it accordingly if necessary...
OK, so i was having trouble with my transmission, then it went out.. so i replaced it with a used one.
But, just as before i changed it, my O/D light was/is blinking.. so i was sitting there with the mechanic while he was going through some kind of blog of sorts checking the codes he got from it, (Which of course i cannot remember now) and i read it with him, it said that;
"If the third brake light is not working it can effect the O/D status and put the transmission into safety mode"
Now while I'm not sure if this is actually true, i did do some searching, all over the forum here and the net, i found nothing that says this..
however, in the mean time my transmission is in safety mode, and it doesn't shift into high gear...
So i am really at a loss of what to do next, I mean does this light actually have an effect on the transmission?
If not, what else should i look for or try to resolve my issue..
Truck Specs: '95 XLT 4x4, A4LD Transmission, 4.0 V6
Note, I have an LED strip ordered and should be here sometime this week.. (I Hope..), I plan on using some information (Which of course I found here on this forum) to replace the fluorescent light/ballast setup..
