I thought I was following it, but now I am not so sure.
I looked at a picture online. The front bushing appears to be pressed in. The rear looks like it has a prong/arm that slips into that rear bushing that mounts to the sub frame. So, I could see that FRONT bushing that's part of the LCA being a PITA to get out. The rear arm/prong that slips into the rear bushing? I would have assumed that slid right in and would be straight forward to get out. No?
Is the ball joint on these a pinch style in that a bolt/nut pinches the ball joint into the knuckle, or is it the type that you have to "pop" out with a separator?
I replaced the LCA's on my wife's 2007 Edge and it had the pinch type for the ball joint - loosen the nut/bolt and the ball joint basically dropped down. From there, unbolt the front bolt into the LCA. Remove the two bolts on the rear bushing and the LCA almost fell out.
My 2011 is what caused all the drama listed above. In the end, I got rid of it; however, I suspect the thumping I had was related to the LCA and/or the rear bushing as they were eventually replaced. The thumping and shimmy went away, but a loud clank developed over bumps at low speeds, which I believe was the front sway bar links. Never found out as I got rid of it.
My 2014 Sport has new struts and strut mounts in the front at 38k as the struts were leaking at 38k - wow! It now has 42k. Every once in a while, I get a knock in the front end, low, that sounds like the sway bar links loosening up. I'm also gun shy about thumping and shimmy after having dealt with the 2011 for months on end. Before long, I'm sure I'll be faced with that and plan to just replace the LCA's, rear bushings and the sway bar links all at once. They aren't that expensive and it's nice to have that new car feel back.
Thanks again for the input.
Shumax
