The tilt steering was standard on all the US models. Chances are very good it does have tilt but someone may have removed the handle. Take a look at the lower left side of the column directly under the turn signal for a slot with a dull metal bar with a threaded hole in it. The tilt handle it literally a bolt with a plastic overwrap molded to one end. You can pick one up from any yard for basically free.
