MINIGfather
- October 10, 2009
Hi guys. Im new here and did a search. But to no avail I got no answers.
I was leaking antifreeze the other day and thought that the head gasket was leaking. I had a shop look at it and they said it was the Timing cover gasket. I was quoted around $600 to fix it. So I got another shop to look at it and diagnose it and they said the same thing and said they would do it for $325. So they fixed that and then there was another leak. It ended up leaking at the head as well.
I told them that I couldnt afford anymore work and bought a bottle of Bars Leak head gasket stop leak as a hope that it will stop until I can afford the head gasket to be fixed.
Heres the question.
It said on the stop leak bottle to pour it in turn on the vehicle and turn the heat on full high and heat and run for 15 minutes. So I turned on the heat and it came out cold.
Is there anything they would have done while doing the timing cover gasket that they could of crossed that would cause the A/C to kick on when in the heat position??
I know its the A/C cuz the compressor kicks on and it blows out ice cold.
Oh yeah...we had heat they night before they worked on it...
Thanks to anyone that helps me out...
Heres the question.
