Ok.....so far so good. (as far as I know
• Put the timing chain, sprockets and guides on (ALMOST forgot to pull the pin on the tensioner...oh man
Torqued all that to spec - Thanks to
@Runnin'OnEmpty for all the torque specs (put a little 243 blue loctite on all these..just a little)
- Cam sprocet bolt (Torx 55) 44 to 50 ft lbs
- Chain guide (Torx 40) and Tensioner bolts (10mm) torque at 84-108 INCH-lbs and 84-96 INCH-lbs respectively
Almost screwed this up and did FOOT pounds, but it was INCH pounds. big...big...BIG difference. ha.
- On my engine, even though it's a 95, the sprocket set was a 93. Which means that there is no "keyway" on the lower drive shaft sprocket. THAT means I had to take off the key to get the sprocket off. Putting the key back on took alot longer than I thought it would.
• Bought the cheapest oil I could find, poked a small hole in the top and squirted it with some pressure down into the oil pan to wash any little pieces of crap that may have fallen in there down to the drain plug.
@fast_dave
• Cleaned all the gasket facings (engine and cover) with brake cleaner and LT. Wiped them til the rag came up clean.
• Used the air compressor to blow out the bolt holes
• Used the thicker Gasket and put Ultra Copper (not too much...I don't think anyway) on either side and the underside (oil pan side)
• I had the water pump on there but was able to get the cover on without TOO much trouble putting in one of the longer bolts on the far top right and lowest left bolt holes.
• Hand tightened the bolts and then torqued in the lower (oil pan) bolts first then went around the timing cover bolts (10mm and 13mm) in a star pattern starting with 10lbs, then 12, then 15.
• It got dark. Time for beer.
I don't see any "extra parts" lying around. So that is good.
Tomorrow it'll be Harmonic balancer time.
Once that thing is on (I forgot to put in the crank seal...but I can do that before the balancer goes on I think.) then....put the radiator back on and change out the thermostat, drain the oil, fill it back up with radiator fluid and see if it holds water without pressure. If it does, I'll drain the oil, was going to buy 4 qts of CHEAP oil, Run it and see if it holds water under pressure. Then change out the cheap oil for the good stuff and at that point change the oil filter.
Thinking being that maybe some left over crap would get caught up in the old oil filter and may as well have it stuck in there rather than the new one.
This all ASSUMES that some how I didn't screw up the timing messing with the sprockets and chain.
I did do one thing that seemed to help me out as I took things apart. I traced the timing cover gasket onto the cover of the box it came in and stuck all the timing cover bolts into that in order.
Then as I was putting it back together, I knew which one went where. Then as I was torquing things down, I'd check off whatever bolt I just torqued and then diagonally across to get one on the other side in the star pattern. Each time I made a pass (10lb, 12lb, 15lb) I put a slash next to that bolt on the cover. That way I was sure to get them all torqued in order and sequentially. Not sure if I needed to do that but I didn't lose any bolts so that was good.
well....hopefully I didn't screw up and miss some huge thing. But....we'll see tomorrow.
Thanks again!
