tire fitting question | Ford Explorer Forums
virtual"x"
Powell River B.C.
'91 explorer Edie Bower
what do i do to make a 33x13.5 fit on my '91?
i have looked at the "lift sticky" and can not figure it out. :confused:
currently have 2"bl and 2" suspention lift with 31's (lots of room left)
will these fit with this lift or will i need wheel spacers?
...Check for a sticky in the tire section..;)
...Ok, I'll play...Which lift sticky did you look at...:scratch:
...I was searching and I came up with this thread..:dunno:
http://www.explorerforum.com/forums/showthread.php?t=155419
...Then I came up with this list that I found here...;)
Dead Link Removed
2 inch body lift and 1-2 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 2-3 inch suspension lift- 33x12.50x15 on 15x8 inch rim
..With 13.50's you might have to get a different wheel backspacing but all tires are built different...Depending on your vehicle, the tires and wheels, and of course the setup, you should be fine with minimal rubbing and/or trimming...
