go with 32 psi this is a base figure for most all veicles for everday economy, proper tire wear, best ride, etc. however go more if you tow something or less if you go rockcrawling
Check your sticker on the drivers door right above the latch. It has recommended tire pressures. It is a good idea to follow these unless Ford has told you otherwise.
