Ford changed their rating to all stock tires are recommended to be filled to 30 PSI. The 16" tires were already rated to 30 PSI, only the 15" tires were originally rated for 26 PSI. After the Firestone issue, Ford started recommending 30 PSI for all tires. There is no official recommended pressure for other than stock size tires since they aren't officially recommended. If your tires are a different brand but the same size as stock, 30 PSI is a good place to start. If you have different sized tires now or just want to be certain you are at the best pressure do a search for "chalk test" you will find a very good procedure for determining the best pressure to run in your tires.
