Just posted what I found out on another thread. Spoke with the dealership parts guy this morning and he says the part numbers are different but because Ford has not supplied them with he actual specifications, he could not answer the question at this time. Not sure if this lack of info applies to all dealerships or not.Anyone find out if 17" wheels will work on the LIMITED (20" stock)?
Of course the caliper size is the main concern, I'm also just hoping that the offsets are the same for Base and Limited in case I did decide to use the Ford rims. I'm reasonably optimistic the brake calipers will be the same size. I had no problem using the smaller Rav4's wheels on the bigger Highlander. Keeping my fingers crossed. In any case, it is difficult to order wheels when no one I've been in touch with seems to know for sure what the offset is for this vehicle.I am actually not concerned about the bolt pattern, or the offset. I am concerned about the size of the brake caliper. Sometimes bigger Wheeled cars will have bigger brakes, in order to be more effective on bigger wheel sizes. You could always order some wheels from tirerack.com. Thats my plan. But I really want to know about those brakes and etc
Jake, I called another dealership today and asked THE question. The parts guy was quite certain that the 17's should fit on the Limited. He said looking at the brake assembly parts for the 3 models, they are all the same. Therefore he could see no reason why fitting them would be a problem. As for the wheels, they are more than double the price of the 2010. They apparently are not the same wheels. $175 CDN here. A tire shop I called said he had 17's that should fit for $85. Since I'm scheduled to get the Ex at the end of the month and will have all of March to go, I may change my plans and get the 17" rims and snows now and give the Hankooks a chance in the warmer weather to see how they perform. Looking at the BFGoodrich Winter Slalom KSI as a possible choice.Anyone find out if 17" wheels will work on the LIMITED (20" stock)?
Can any one confirm if 17" wheels can fit on the Limited yet?
$257.03 per wheel? Is that for the Base model steel wheel? My dealer quoted $174 and change (CDN) for the 17" steel wheel. A local tire company gave me a price of $84. Something doesn't sound right here. TPMS valve was another $54 each.Hey Jakefeb3,
This is Seni with Ford Customer Service. I believe the answer is yes, 17" wheels can fit on the Limited. I am stating yes because I see them available for purchase on our Ford Parts website, http://bit.ly/etIcrg. Please let me know if you find any conflicting information, so I can research further. If there is anything else I can help you with, feel free to contact me.
Seni
Ford Customer Service Division
