Really? I thought 95 and 98 had the same combustion chamber. Doh!
Not much I can do about it now. Be another $500.00 to change heads.
Thanks JD. Im just exploring options since I'll have both heads off again anyway.
Here is what a side by side looks like on my lower intake. I've included a pic showing how the upper part doesn't really need much work. I did touch up the unside though, without blowing thru the walls and epoxying. Way to much work for me.
what did you buy?yea i was going to say do the tb mod and might wanna do a 5.0 maf.yea you did a great job man looks real good,biggest place is near that injector and bottom runners.with that porting and new valves you should feel a little difference in powerThe Maf is stock.
The TB is stock with the half shaft mod.
I did a buy from the same guys that did the group buy almost 2 years ago now. Full housings. I really need to take a picture of my X and post it.
I made it up the runner about 2 inches from the bottom, then I touched up from the top. I really didn't want to blow thru the outside wall. Im sure its not as thorough a job as you have, but way better than it was. Took about 4 hours. My compressor isn't really up for the task so there was wuite a bit of wait time.
I won't be measuring. I don't have confidence in my ability to do that.after you measure for pushrods any youre sure you have it correct. if its 5.525", i have a set of them, smithbros.
what is 'shaving heads'? taking off a thin layer of the bottom of the head(headgasket surface)? or is it something else?
