1998rollover
- November 10, 2008
- Weiser, ID
- 1998 Mountaineer
What causes the PCM to decide there's not enough fuel being injected and respond by opening the flood gates?
I've replaced the injectors, pressure regulator, fuel pump, filter, throttle position sensor, oxygen sensors, catalytic converters, plugs, wires, coils and cleaned the MAF, throttle body and IAC with appropriate cleaners.
It has a cat back dual exhaust too, but it was having issues before that with a persistent 0175 code.
Now it randomly has any or all of 1320, 1321, 1322, 0171, 0172 and 0175 codes.
I looked up the numbers on the Delphi FJ10236 injectors and they're supposedly the same 19lb flow rate as the original F6VE-A5A. I'm tempted to try some of the white 17lb injectors to see if those will cut the fuel flow down to what it should be. It pours in so much excess fuel that it only runs decent at over 65 MPH.
Could it be something gone wrong with the PCM and it's defaulting to a fail safe mode to avoid running too lean and melting the cats?
The vacuum line to the reservoir for the blend door got melted through (AC only out defrost). I repaired that but now it's doing the thing where under hard acceleration it switches to blowing hot air out the dash and sometimes shuts off the cruise control. The only hard line I could get where that happened was a bit smaller inside diameter. Too restrictive?
