- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
It sounds great, very subtle/normal muffler sound. I hope the exhaust is big enough, it could use a dual 3" or more volume/size given the turbo.
BTW, I see the washer bottle in front. I pondered moving those myself to make room for a turbo. I think I could have used the rear washer bottle to feed both the front and back, with some modifications. I bought a rear reservoir to play with, to see if I could install the front washer pump into one. The 98-01's have no rear reservoir, they use a special pump with two outlets. If the pump could go in the rear 95-97 reservoir, then the wiring and lines could be reworked to use the rear setup, and eliminate the front reservoir completely.
