wgloff
- December 17, 2015
- 2002 sportrac
2002 sporttrac 4.0 4WD, limited slip rear axle, 171,000 miles
Trying to keep someone on the road with no funds.
The rear axle clutches are worn out, and destroyed the side and spider gears. Bearings and ring and pinion are actually OK. Lots of end play in axles, due to clutch pack facings being gone.
Is it possible to shim the clutches to take out play in axles? Really do not care if limited slip works. I have access to shims.
