JGood325
- February 1, 2007
- Lancaster, PA
- '97 5.0
I'm having this issue where I'll start the truck, the idle will be high, and it will shift at unusually high RPM's (3-4k) under normal throttle/load. The torque converter also won't lock. If I shut the truck off, restart it, there is a 50% chance the problem goes away until the next time I start the truck. So I'm guessing it's something electric or a solenoid or something. Sometimes it will happen while driving - everything is fine, then I'll look down and see I'm turning 3500 rpm's doing 70mph, because it won't shift to overdrive until 3800 or so.
I don't know anything about auto tranny's, especially Fords, so what are some common things to look into that would cause this?
Other issues the truck is currently having:
-Gaping hole in EGR tube (will replace soon)
-Intermittent shudder at 40-45mph under moderate load
Thanks in advance for any advice!
