Dave98XLT
- February 18, 2007
- VA
- 98 XLT 4WD 4.0 SOC
I have been towing my boat (about 3500lbs) with my bone stock 98XLT 4WD SOHC. I wonder what type of risks to the transmission and engine I am taking doing this? I would like to be able to tow long distances but haven't gone more than about 75 miles so far.
What would be considered the optimum vehicle for towing this type of load, when I say optimum, the smallest vehicle I can get away with for fuel economy reasons? Or is it possible to mod the explorer for this?
I would consider adding an oil cooler or two to help reduce wear to the engine or trans. It already has a small cooler of some sort in front of the radiator. What is the easiest route to take to get any needed additional cooling? Will this alone do the trick?
Is the transfer case another concern running ATF?
The trans shop told me to take it out of OD in the mountains but OK to use OD on fairly level roads. Not real happy with the 4spd trans performance, sometimes it drops down from OD to 2nd gear on a hill. I figure I am stuck with the downshift problem and need to learn to drive so it doesn't happen so much, take it out of OD when approaching hills, etc.
Other than that I am pretty happy with the ride and braking when towing. Rear discs help a lot and you definitely want all the air out of the brake lines. And no texting while driving!
Thanks for reading, and I would appreciate some advice. I know there are whole books written on this site about mods but I am hoping someone can help me avoid too much experimenting or worse killing the vehicle.
