bad.shimmy
- November 28, 2007
- auburn wa
- 91 eddie bauer
i went out and was checking the voltage on the tps and vref was where it should be around 5 volts. but the signal voltage which is supposed to be almost a volt was reading .08 and ramped up to .68 when i turned the throttle to wot.
i did a voltage drop and it was under .5 volts
bad sensor right?
btw this was done with the key in the on position.
bad sensor right?
