aj213121
- May 29, 2011
- Sport Trac '03 XLT
Ok so a few months ago i heard grinding coming from my car. I replaced the hub assembly and that did not help. Replaced my cv joint and the grinding was still there. And now just recently my car decided to stop while driving and not go into gear. My car does not move when in drive or reverse...only when in shift it to the 2 gear. I thought maybe the cv joint was put in wrong but that didnt help and i spun my wheel again and noticed the grinding seems to be coming from the trans? Is my trans gone or could it be a worn out axel joint i believe the part is called? (The part that connects cv joint to the drivetrain)...i was just confused because only the 2 gear works. Thanks
