Trans won't shift | Ford Explorer Forums
Trans won't shift
SARBronco
Ephrata, PA
'93 XLT
Ok new to the forum but was pointed here for help on my daily drive. Here is the problem...
I want as many ideas as I can get. My explorer (93 auto) needed a trans service, though I can do that so I did. Long story short, I sheered a bolt in the housing and it took a long time to get free. The car was on jackstands for like 2 months due to my lack of free time and other projects needing finished. Got it all buttoned up today (2AM) and everything seamed to work properly. The only thing I did not do was to let the tires spin on the jackstands. Put it on the ground and now it will not engage in gear, any gear. What did I do here? Thinking that maybe the new filter is not in properly but not really sure and don't want to drop the pan again if can be avoided. Sorry that my first post is a cry for help but I promise I will be better productive later.
Moving to Transmission & Transfer Cases forum.. Oh yeah shorten your signature down to 6 lines or less per the rules listed in the FAQ.
Sig shortened, sorry missed that part thanks for pointing that out for me.
I think that my issue is that my tourque converter has drained, how many quarts to fill this up? I am sure that I can search for hours and find this but want to check to see if anyone knows off hand.
Just under 10 qts for 2wd, 10 qts for 4wd.
Fixed, thanks everyone
Ok added more and should be it, it works in the garage at least, time for a test run. Thanks for all the help. We added about 8qts there were 2 that were not totally full to start with.
