justinf89
- April 21, 2010
- Hampton, VA
- '97 xlt 4x4
The 5r55e calls for mercon V but the transfer case calls for mercon? That doesn't make much sense since mercon v is supposed to replace all mercon fluids. Somebody told me today that I was supposed to put the dexron/mercon general fluid in the transfer case but would it be better to use mercon V? Also, does anybody know how much the 5r55e holds? I hope to drain the t-converter. The only fluid I can imagine will be left after I change the filter and drain the converter will be in the lines and cooler. Thanks for the help.
