mranderson214
- August 3, 2010
- Brooklyn, NY
- 2002 XLT
Hello Everyone,
Firstly I'd like to thank everyone on this forum that has helped me in the past with my Explorer. I recently hit 200,000 miles! I probably couldn't have done it without the tips and assistance from many on here.
I have a 2002 Explorer XLT, V6 (4.0 L), 4x4 with about 200,400 miles on it, pretty much all stock.
Lately I've been having some sounds out of what I believe (and was told) was the transfer case. When I reach about 40 mph and let off the gas, I get a popping sound as I decelerate about 75% of the time. Once I hit above 50-55 mph, if I let off the gas, I will get a buzzing sound similar to a drill and the speedometer and tachometer will surge a little bit. The sound and symptoms will go away if I put the truck in Neutral or if I step on the gas pedal.
Lately, I've been having to drive sort of like a manual. If I have to go over 50 mph, when I get ready to slow down, I'll put it in Neutral and if I need to put it back in Drive, I'll try to match the RPMs before shifting back. This seems to be working flawlessly so far but I know a problem exists so I'm going to a transmission shop tomorrow morning for a diagnosis.
All 4 tires are the same thread pattern, and size, make etc. At one point a few years ago, I had different thread tires on the front and back and would get a bucking sound when slowing down from speeds over 30mph. I later learned that this was due to different rolling diameters of the tires and fixed the issue by replacing the tires. This isn't the same sound, but I have similar symptoms in that it only happens when letting off the gas after a certain speed, which leads me to think its the T-case.
The transmission is fine. I just had my fluid checked/changed a week ago and I have no O/D light or anything. One shop I went to told me that my transmission is still in "great condition" and that they think its the T-case. I don't want to throw a ton of money into the truck, but she still rides extremely smooth (for over 200K miles) and is in good condition to give away.
Has anyone had any similar experiences that would give me some insight when I go to the Transmission shop tomorrow? I always dreaded the day that I had to go to one considering transmissions and probably the most expensive thing to repair/replace on a vehicle. Any thoughts would be greatly appreciated.
Thanks,
Thanks,
