chascath
- November 23, 2001
- Charlotte, NC
- '97 XLT
VEHICLE: '97 Explorer XLT, V6, 4.0 SOHC, AUTO, 52,000 miles
Just got back from the dealer shop with what I thought would be a very minor engine oil leak due to a loose filter or plug, or some other minor nuisance item from my oil change service two weeks ago. (Note: I checked the engine oil level yesterday and it was full.) After sitting for 12 hours I would get a nickel to a quarter size spot of what appears to be oil. To no surprise with my recent luck, the tech guy informed me that it is the transfer case oil. I have a "very small hole" in the seal. He topped off the transfer case oil and stated it was less than half-quart low. He also stated that when driving the wind would sling the fluid to other areas of underneath including oil pan area. Nothing to be immediately concerned about but it will in time get progressively worse and recommend transfer case seal replacement in the very near term future. I made an appointment for this coming tuesday. Fix-it cost will be around $450 which I hope my extended warranty policy will cover. There was no charge for today's time.
The oil filter and oil pan plug are both tight and never caused a problem. I wiped areas around the oil pan and the transfer case and placed some paper underneath in an effort to pinpoint the problem myself. So far I have seen no evidence of transfer case leakage after about 12 hours.
QUESTIONS:
1. How common has this been in explorers?
2. Is there a way to visually tell the difference between transfer case oil and regular engine oil??
3. When driving, is the transfer case fluid under pressure which would exacerbate the leakage (force the liquid through a compromised portion of the seal)?
4. Shouldn't transfer case seals last longer than 5 1/2 years and 52k miles??
5. Is the stated estimate of $450 (parts and 4-5 hours of labor) sound reasonable for this work??
thanks........
QUESTIONS:
thanks........
