TIMBELL99
- January 3, 2009
- Lynchburg, Ohio
- 95 Ranger Super 4.0 4x4
Hello;
I have a 96 Explorer, 4.0, with the 4405 transfer case. It is a bit confusing to me because the control on the dash has 2wd/4wh/4wl. It doesn't say "Auto" anywhere, nor do I have a neutral position for the transfer case. Everything looks original. BTW, I have a 5 speed manual transmission.
My question is, is it possible to disable the transfer case to prevent it from going into 4wd? The transfer case that is in it right now has the popping sound when going slow and I think it was damaged from the previous owner by driving it engaged. When I bought it the front axle was engaged and I had to unlock it by attaching a vacuum pump to it. Now that I have the front unlocked, I am going to replace the transfer case, but I do not want it to work.
What are my options? Could I leave the front driveshaft off, or remove the chain from the transfer case itself? If I can remove the chain, I could use the old transfer case and not disturb the good one I have.
I have tried to use the search function, but has confused me a little more. Doesn't take a whole lot.
Also, do the tranfer cases from a manual and auto mate the same? Looks the same, and the numbers match, but I have learned that doesn't always mean they will bolt up.
Thanks for your help.
Tim
96 Explorer 4x4 Manual shift
95 Ranger Super 4x4 4R55E
Tim
