MADMEXLS
- January 3, 2024
- Sacramento, CA
- 2004 Explorer XLS 4WD
Hello everyone, I have a 2004 Explorer XLS with a 4.0L and a 5r55s (code: V)
This car currently has 61,x.. miles on it and ive had it since 49,x... It was garage kept by my grandfather and everything up to 49,x.. has been maintained as per the owners manual. Since ive had the car, its had an issue of going into neutral and just reving after an emergancy or hard stop. After a few seconds it jolts the entire car back into gear.
From what ive read this is a common issue of tranny low fluid, however this past weekend I checked the level and it seems fine with fluid dripping out of the check plug hole. To ensure I did it correctly I will write about how I checked the fluid. I used a OBD scanner and with tranny temp at 112, I then jacked up the car on 4 stands and had them as even as possible on a driveway. I then shifted through all gears and ended in park then opened the fill plug. Clean red fluid dripped out so I assumed it was as proper level.
I will check the fluid again today or tommorow just to be sure it was at proper level and do a complete filter and fluid replace. But any ideas as to what it could be or what failures it could be pointing to? (i.e. solenoid pack failure)
Thanks!
Thanks!
