Transmission interchange question | Ford Explorer Forums
MotownGT
St. Clair Shores, MI
1997 Explorer Sport
Will a transmission from a '98 Explorer w/ 4.0 OHV work properly in a '97 Explorer with a 4.0 SOHC? Both are 4x4.
Is there anything I should be aware of before doing a swap like that? I can get a very nice price on a low mileage trans from the '98, but I won't bother if it would require a bunch of other modifications.
Thanks.
Thank you for the quick reply!
Just to make sure I understand your other thread-when you say "bypass" the ODS, you're just referring to cutting the harness at the plug and soldering the 2 ends together, correct?
Thanks again.:)
