Transmission Issue? | Ford Explorer Forums
Transmission Issue?
lynnc7738
Oak Ridge, TN
2007 Sport Trac V8
[My 2007 V8 Sport Trac with overdrive seems to slip , like a miss, when in overdrive. I can switch it out of OD and it stops. It has 83,000 miles and runs very well except for this. Plugs are Ok. Any ideas?
you're getting close to the transmission fluid change for a start check for codes, then check the fluid level and color, here's a chart of the fluid colors just in case, from what I've seen it's a band problem but was common en 00-04 models, i have a 2007 ST V8 limited with 98,000 miles did my service at 93,000, just reaching the 93,000 it was getting stuck on first gear did my transmission service new filter and fluid and was all gone shifting smooth, only use Motorcraft Mercon V
http://www.agcoauto.com/content/images/transmission/automatic_transmission_fluid_color_chart.jpg
Thanks for the suggestion! I'll check it tomorrow.
Glad to help!
Doesn't the 6R60 require Mercon SP?
CAUTION: MERCON®, MERCON® V and MERCON® SP are not interchangeable transmission fluids.
The use of any other fluid or cleaning agents will cause internal transmission damage.
https://www.scribd.com/doc/249763868/Automatic-Transaxle-Transmission-8212-6r60-Specifications
http://www.fordparts.com/products/chemicals-transmissionfluids.aspx
https://www.fcsdchemicalsandlubrica...mission%20Fluid&category=Transmission%20Fluid
You're right Mercon SP is the right fluid, my bad.
My 2007 V8 has the 6R60 Trans?
Yes.
I found Mercon SP at Advance Auto by my house. Autozone did not carry it. I just went through all of this myself. You may want to crack that 3/4" dipstick/fill nut loose while it is still cool enough not to burn yourself. Mine was TIGHT. I then tightened it back up and checked everything once it warmed up.
