Transmission Leak! | Ford Explorer Forums
Transmission Leak!
burtonbrd138
Massachusetts
2000 Explorer XLS
I have a 00 Ex an the transmission filter was replaced a month or two ago. The guy that did this also put new transmission fluid in it and put way to much. The reaso i brought it to the shop is because it was leaking and what he did was supposed to fix it. It still leaks so i called him. He said it is leaking because there is too much fluid in and it has an overflow valve at the top of the transmission and it is leaking out the fluid it doesnt need. Is this true?
