C420sailor
- July 29, 2008
- Long Island, NY
- 98 XLT SOHC, 99 EB 5.0L
I’ve noticed a bit of an uptick in transmission posts here lately, and figured I’d start a thread on ‘best practices’ for increasing tranny longevity in these trucks—especially the weaker gearboxes like the 5R55E.
These tips have allowed me to take my transmission to over 340,000 total miles (200,000 since last rebuild), and she is still going strong.
Feel free to add in something that has worked for you.
1. Change your fluid. I’m not sure exactly what the recommended interval is, but fluid is the life blood of your transmission. Unlike engine oil, which is only used for lubrication and cooling, transmission fluid also functions as a hydraulic fluid. This means that it acts on items with seals. As friction material in the trans (torque converter clutch, clutch pack frictions, etc) wear, these particles begin to circulate. Now, pay attention to what I just said—FRICTION MATERIAL. You don’t want this eating away at bores and seals. I change my fluid every 30,000mi, but whatever you do, change it before the color begins to change, and change it regularly with Mercon V ONLY. Install a drain plug in your pan to make it easier. If you rebuild your transmission, see if you can get a torque converter with a drain plug. Stock 5R55E guys can use the cooling line/bucket method.
2. Warmup. I know this is controversial. Many articles have been published saying that warming up a car isn’t necessary (some say it’s harmful), but these articles usually focus solely on the engine cylinders. Remember that a powertrain is more than just a set of reciprocating pistons. In this case, we are using an oil-based fluid to hydraulically actuate parts within the transmission. Cold fluid has a higher viscosity, which will result in higher pressures. Cold fluid means cold seals, and cold seals tend to be harder and more brittle—prone to blowout and/or tearing. Giving the truck even just a few minutes to warm up, especially in cold weather, can raise fluid temperatures enough to be more gentle on your transmission when you put it into gear. Also, the lowered idle RPM of a slightly warm engine will be easier on the transmission when you select a gear. Warmup also helps your power steering system! If you have a block heater, use it! That heat will migrate to the transmission.
3. If you tow, or you live in a very hot climate, consider adding an auxiliary cooler (or a larger aftermarket cooler). Cool (not cold) fluid is happy fluid.
4. Consider installing an external fluid filter. There are various types. Some are magnetic and simply plug into the cooling loop near the cooler. More complicated systems involve bolting a spin-on filter housing to your frame. I made my own version of the latter and it functions very well, as oil filters have much finer media. Make sure you take into account cooling loop flow direction.
5. Periodically change your pan filter. These filters are designed to catch large particles. Most are 80-120 micron filters. Oil filters are in the 10-30 range, for comparison. This doesn’t need to be done every fluid change, but come up with a regular schedule. While you’re in there, clean off your pan magnet and, using a good inch-pound torque wrench, check valve body torque. Make sure you reference the torquing diagram and values in the service manual.
6. Come to a complete stop when changing gears, and allow the new gear to fully engage before stepping on the gas. You’d be surprised how many people don’t do this.
7. Don’t beat on your truck. Don’t drive hard if you don’t need to. Sometimes I need to accelerate hard, but I try to come off the throttle a little in anticipation of the next shift, if I can.
8. Adjust your bands. The R55 boxes have adjustable bands. They don’t need adjustment often, but regular adjustment will make the bands last longer.
9. If you need a rebuild, find a QUALITY shop (if you don’t DIY). The better the warranty, the better the job. Many of the shorter warranty shops will simply replace what is obviously worn (frictions, maybe the torque converter too), gaskets and seals, and hope you make it past the 12-month warranty. Ask them if they rebuild the transmission to current Ford specifications. Ask them what company they use for various parts. Ask them what they replace. Ask questions.
10. Maintain your driveline. Worn CV or u-joints introduce slack, which can cause shock loading during gear selection and driving. That shock will shorten the life of your transmission.
11. If you’re running big tires, seriously consider gearing. Big tires with tall gearing imparts more stress on the transmission.
12. Don’t forget your transfer case! Change the fluid regularly with the appropriate fluid. Mercon V is NOT for use in transfer cases.
13. If you get a flashing OD OFF light, or if you notice funky shifting or trans issues, address it IMMEDIATELY.
14. If you’re towing, or driving up a long, steep grade, consider using the OD OFF button.
What else do you guys have? Let’s hear it!
