ke398
- October 28, 2007
- 1996 Eddie Bauer
Hi Everyone,
I just found this forum and unfortunately I am asking a question for my first post. But any help would be greatly appreciated.
My wife has a 96' Explorer, 4.0, Automatic, 4x4 control trac, and I think it has the 4r55e, I think.
We were driving last night and the transmission started to slip. We made it to our destination about 5 minutes after the slipping started. When we were driving, as long as we kept our speed up the truck had no problem pulling a hill.
When we stopped we could no longer go forward or in reverse. The only way the truck would move is if the rpms were over 3000-3500, And it would barely move then. 1st-OD and reverse all had the same problem, I turned off the o/d switch and no help there either.
I did check the fluid and it was fine, probably needs changed but was not burned. The transmission seemed to shift through the gears fine but no movement at all, unless the rpms were over 3000.
Any ideas guys, I could really use some ideas here, I am on a tight budget here, and if I can fix it myself it would be great. Any help is greatly appreciated.
