Transmission question. | Ford Explorer Forums
scas
Edmonton, AB
'93 Sport
Has anyone ever tried to put a 5R55 into a first gen? The extra gear would be a great thing, since the stock one is only a 3 s with a O/D
you would need a transmission controller like this:
http://www.shiftkits.com.au/index.php?main_page=product_info&cPath=14_26&products_id=30
Or this, for much cheaper:
http://www.powertraincontrolsolutions.com/transcontrol.php
or you could just swap the engine transmission pcm and full wire harness from a newer explorer.
If you were going to change out for a newer transmission though, where you are gonna have to buy a controller and whatnot.... I would go for something like a 4t60HD or an Allison 1000 if you want a 5 speed auto. 4th gen allison is available with a 6 speed.
Your A4LD has 4 gear ratios. 5th gear on a 5R55E is virtual. It's a trick that the computer is capable of doing by combining gear ratios. James has a sticky thread in the transmission section on swapping a 5R55S.
