1996BLKBauer
- June 24, 2011
- McHenry, IL
- 1996 Eddie Bauer AWD V8
So my Explorer has had some transmissionish problems, or it seems that that the transmission is the problem. A delay in acceleration, and jerking into 2nd or 3rd gear, along with a slipping or slamming into the same gear. I am not entirely certain what transmission I really have, but I believe I have the one that is in my Specs sheet on the site here.
Enough rambling, I am contemplating, doing a change of the fluid, many people on here said that they did that with the transmission I have, or think I have, and that the problems have gone away. On the other hand all the older mechanics my dads know, have said to me not to change it because it will not move again. I have almost 162,x.. miles on it now, on what I assume is the stock fluid, not sure because I have only owned the truck for a year and a half.
So I am sort of at a standstill here, not sure on what to do, or even what brand of filter to go with, I am thinking WIX filter, when/if I get one. I would really would like some input here. I am also thinking of changing the transfer case fluid, before winter hits here, is it true that it takes ATF fluid? if it does, I may just change it this Sunday, it is suppose to be 60 degrees and sunny.
So my main questions are how do I identify the transmission I actually have. Should I change the fluid, and what could really be the problem?
